ECU Bespoke Triking Re-map IAW15M
Date:22nd August 2017 8:00 pm
TRK3D02-001 new mapTRK3D02-001 map changes
Re-mapped ECU, This is a dedicated program / map which has been specifically developed for the Triking, boosting the low to mid range power delivery while improving fuel efficiency and smoothing out incidental flat spots often found on the std motorcycle ECU map tune.
This can be supplied as a re-program installed in a customers own ECU on a rapid turnaround service or….
As an exchange ECU , this option can be supplied as a pre-programmed unit while the customer retains their own ECU, giving the opportunity to test the new program in direct comparison to their existing map.
Suitable for any Magneti Marelli IAW15M ECU typically found on most post 2000 model Trikings fitted with EFI
Best results are obtained with K&N or equivalent type of free flowing air filters and std Moto Guzzi factory engine / mixture settings.
Print
