Pedal to master cylinder extender, Used where a pedal assembly is located rearward of the front bulkhead, Available in 60mm and 120mm lengths which covers most driving positions, Robust alloy construction with high tensile steel insert, 5/16 UNF male / female threads, Fits fully home on the pedal connection end while retaining full adjustment at the master cylinder. Developed for Triking T4 models but adaptable to any application using standard fitment components.
We recommend re-enforcing a floor mounted pedal assembly where it is not fixed direct to a front bulkhead.
Available individually,,,,,,
Short, 60mm £14 each
Long,120mm £16 each
